Airborne Janitor Posted April 16, 2017 Share Posted April 16, 2017 In my quest to swap a 97 AW4 into my 89 MJ I was unable to find wiring diagrams that were helpful. Although I found the proper years I found the colors were not matching up, so I decided to swap the wiring harness from the 89 into the 97 AW4. Although the solenoids are a little different everything plugged in like it was meant to. However when I went to remove the rear speed sensor... I didn't realize you could push the sensor out from the output shaft side with a small prybar. Of course I realize this after I break both sensors trying to wiggle them out, I'm an idiot. As far as I can tell this sensor is identical on both my 89 and 97 transmissions. I'm assuming 87-97 sensors are interchangeable. This doesn't appear like it can be repaired, as the plastic "shell" is broken and the solder at the tip of the sensor is broken as well. Does anyone have a lead on one of these? Thanks. Link to comment Share on other sites More sharing options...
Airborne Janitor Posted April 17, 2017 Author Share Posted April 17, 2017 Did a little homework and found this is Mopar 83503722. Crown also makes a replacement, price around $65+. Will have to see if I can get lucky at the parts yard, I couldn't have broken a cheaper part could I? Link to comment Share on other sites More sharing options...
