ComancheKid07 Posted January 29, 2017 Share Posted January 29, 2017 I have a 1987 with the 2.5l engine and the previous owner pulled most of the A/C components but left the compressor. It doesn't seem like there is a A/C bypass pulley made for this truck, I also can't seem to find an alternator bracket for a non-A/C 2.5L. With the compressor pulley/clutch removed and a shorter belt, the belt rubs itself at the idler pulley. Anybody have a solution or a lead on a non-A/C alternator bracket? Link to comment Share on other sites More sharing options...
Marine1Texas Posted January 29, 2017 Share Posted January 29, 2017 I would check ebay. Dorman makes a A/C Compressor Bypass Delete Pulley for just about anything however I see non listed for the AMC 2.5L. Dorman 34171 is made for the 1991 and newer 2.5L, however I don't know if it fits. some one could chime in further. If your a/c is free moving I would not worry about it, it will not engage the clutch, unless you clutch is rusted engaged, then they have rebuilt kits for the clutch. Link to comment Share on other sites More sharing options...
