1989 comanche mj Posted August 25, 2016 Share Posted August 25, 2016 I got this off a 94 zj, is it worth swapping on my MJ? I can't figure out how to add pics, how do I? Link to comment Share on other sites More sharing options...
ParadiseMJ Posted August 26, 2016 Share Posted August 26, 2016 The V-8 ZJ tie rod is a heavier solid bar. I'm not sure if the drag link is heavier duty or not, as I've heard it both ways. A 4.0 ZJ tie rod is the same as an XJ. The V8 ZJ bar is physically heavier and larger. It has a bend in it where the XJ bar is straight. The bend doesn't affect anything really. Just be sure to measure your tie rod when it is still on your Jeep end to end...carefully...to the 32nd of an inch. Then adjust the "new" bar to that exact dimension. Then just drop it in and bolt it up. Done. Link to comment Share on other sites More sharing options...
