back racks
got the back rack mounted up.   rack was part number 10313 listed for a 1996-03 DODGE DAKOTA 1997-03 TOYOTA TACOMA and the mounts were 92001 tonneau  adapter slightly modified to allow me to still use my tool box.
overall the fit is pretty good. the side hoops sit a little high but the top cross bar with the tonneau adapter goes perfectly around my cargo light and sits about 1/4" higher then the cab.
if you don't have a cargo lamp the standard mounts will work fine. and the adapter brackets not needed.  but with the cargo lamp the bar ran right across the lamp, effectively making it useless.
