The starter relay I bought is marked for the ground terminal and I don't remember switching the ground and the ignition wires around but I noticed today that the ground wire (black with white tracer) was reversed with the green ignition wire. The Chilton manual shows the black/white tracer is grounded and it is.
Here is my question. Is there supposed to be power on the ignition terminal at any time? There hasn't been power there when I test it with the key on. The relay does function to turn the motor over from the new ignition switch but there is still no fire with those two wires where they should be. I thank you in advance for any ideas and help!
