JasonB Posted February 22, 2016 Share Posted February 22, 2016 So i'm thinking of doing this socket replacement with the Dorman Part number on my front blinker. My blinkers don't even come on and no hazards. Occasionally if the headlights are on the left indicator on the inside shows up solid. There is power to the socket and I'm using brand new bulbs (2057A) but when the bulb is placed in socket I get no light or blinkers. I've checked my fuse (turn signal/backup) in the fuse box under the dash and swapped out the blinker/hazard fuses. So what do you guys think is my problem? I know guys have had similar issues with grounding etc but I was wondering what everyone thought in this particular case as to what's going on. Any help would be appreciated. Link to comment Share on other sites More sharing options...
Eagle Posted February 22, 2016 Share Posted February 22, 2016 If you have power at the fuse and power at the socket, but no light, ground is a likely suspect. The fact that the turn indicator on the dash sometimes lights up is a clue that the circuit is seeking a ground by back-feeding through the indicator. Link to comment Share on other sites More sharing options...
JasonB Posted February 22, 2016 Author Share Posted February 22, 2016 Any idea which ground and where to start looking? Link to comment Share on other sites More sharing options...
