dkmcgowan Posted November 30, 2015 Share Posted November 30, 2015 I have an 89 that I just converted to a manual. It's a 4.0 and I put an AX15 from a mid 90's Cherokee on there. I put a Cherokee front Dana 30 axle as well. I'm looking for a front axle that will work. I ended up just getting my rear drive shaft shortened. I'm in the Atlanta, GA area. Link to comment Share on other sites More sharing options...
Black89Comanche Posted December 1, 2015 Share Posted December 1, 2015 might this work? http://www.ebay.com/itm/87-96-97-98-99-00-01-JEEP-CHEROKEE-FRONT-DRIVE-SHAFT-4-0L-AT-4641-/151900576887?hash=item235dfadc77:g:V3kAAOSwv-NWXLSG&vxp=mtr Link to comment Share on other sites More sharing options...
90comancheswb Posted December 4, 2015 Share Posted December 4, 2015 The eBay listing is for an automatic transmission equipped vehicle. Auto shafts are slightly longer than the one for the AX 15. You can take the auto driveshaft to a driveshaft shop and have it shortened to fit. I recently had one shortened and it cost me under $40. In the tech section there is a chart with driveshaft lengths. Hope this helps Link to comment Share on other sites More sharing options...
dkmcgowan Posted December 4, 2015 Author Share Posted December 4, 2015 I noticed that.. I saw a couple on eBay that looked right, I figured I would check her first in case someone had one in the garage and wanted to clear out some space. I probably will run by the pull a part this weekend and see if I get lucky before paying shipping on eBay. Link to comment Share on other sites More sharing options...
