Comanche seats
Comanche 87
I can't find any good seats that fold forward at scrap yards for my 'Manche. Most are shredded or missing. Are there any other seats from other 2 door models or makes that can be easily swapped with/without an adapter bracket? Or should I just buy new ones? If latter is the case, where can I buy them?
The floor seat brackets are Comanche specific.  You can use bench or bucket seat brackets.
The fold forward seats are from a Cherokee or a Comanche.  Same mechanism
Here is what I did:  Look for 2 or 4 door seats with great seat covers in the color I wanted.  Buy them.  Next, buy a set of Comanche seat brackets. Then buy a set of fold forward seats with a good frame.  The rest of the fold forward seat doesn't matter, it is the good frame you want.  Then mix and match to build a great set of buckets.    I used something like 4 sets of seats to put together the buckets in my Comanche.  Make sure some of your buckets also have good foam - you can use the foam from the passenger side on the driver side.
