csgoat Posted June 19, 2015 Posted June 19, 2015 Alright, i hate to see this one go, but it is that time. I finally got her running right back in Jan and the same day I got the engine purring, I was T-boned. Truck still runs great, but does have some body damage. Looking to get 2500 obo. 4.0 RWD Auto Crap ton of new parts. Needs body work, has a vacuum leak on the side of the fuel tank. I hate to sell this truck, but with a baby on the way, I am not going to have the time or money to get her where she needs to be. Message me with any questions. No rust, everything else on this baby is great. Had the paint job done when I bought it because there was a lot of surface rust, had it taken down to bare metal and a couple coats applied. Perfect project truck, when done, will be a real beauty.
csgoat Posted June 20, 2015 Author Posted June 20, 2015 I can get pics of the motor tonight (saturday) when I get home. Parts: Idle Air Control O2 Sensor Manifold Gasket Ignition Control Module Removed Fuel Pump Ballast Fuel Filter Plugs and wires Fuel Rail Clips have been replaced Distributor cap and rotor New tires all the way around Air Filter MAP Sensor TPS Crankshaft Position Sensor Valve Cover Gasket Modified Exhaust-took out Catalytic converter and changed to Magnaflow muffler with a short pipe C101 has been cleaned Majority of wiring connections cleaned I feel like I am missing some, but that is the majority.
csgoat Posted June 27, 2015 Author Posted June 27, 2015 Sorry it has taken so long to get these pics in, Been one hectic week around here, these are links to Pics of the Engine, Straight 6, 4.0L https://drive.google.com/file/d/0B9aMQfsEVBTuZThvQzFodHFqM3c/view?usp=sharing https://drive.google.com/file/d/0B9aMQfsEVBTuajYwOEM4OTNnSFk/view?usp=sharing
Archived
