Knucklehead97 Posted July 11, 2015 Author Share Posted July 11, 2015 The top one is the new block. The bottom is my current one. Theres only two differences that I can find. 1, is the new block actually DOES NOT offer a "flash to pass" option. The second is that the new block has this red wire coming out of the front and it actually has a plastic plug with a tab to remove it. I'm guessing that it is to add a fused power connection to an accessory? Because on the back the post beside it is connected to a post-strip powered from 1 big red wire. Otherwise everything seems to be the exact same! What do you guys think I should do about keeping my flash to pass option? Because I do enjoy having it. I may see if the terminals are still good on mine and just swap them over. Link to comment Share on other sites More sharing options...
