I have a couple sets of factory rims and I would really like to use them!
My favorites are the Jeep 10 spokes. I do have the center caps for them.
Image Not Found
I have a set of Trexus 31" swampers to put on them. I feel they are gonna rub on my LCA's in the front. I have a 3" lift now and its going up another 3" come spring, so its not the height I am worried about.
I ordered a set of 1.25 spacers just incase.
What do you think?
CW
I have the same rims.
31x10.5s rub at full lock. and I mena only at FULL lock. I can turn the wheel to within and 1/8th of a turn of lock. I plan on just shimming up the adjustments on the axle. As soon as I get them unstuck.
I also read about using WJ LCAs, they have a bend in them to clear tires.
1.25" spacer should be enough.
Thanks man!!
I have the factory LCA's just now. But will be lifting another 3 inches come spring and have a set of R>E> control arms going in then!!
Got any pics? I LOVE these rims!!!
Here is mine now:
Image Not Found
CW
body's in great shape. Nice and straight, not a lot fo rust. I'v got 2 places on the sheetmetal that need taken care of. In the spring I'm gonna pull the bed and do like 512tr and por-15 the whole frame. This is planned to go with new brake lines from the master back.
I had to do the rear brake lines as well...thing its the way it is for MJ's! Doing it with the bed off is smart!!
I have rust the bed is prety bad. I cut out what I could find and covered with the diamond plate. The rockers are gone but not aweful, i will be fabbing up some rocker protection to fill the area back in. the cab corners rusted thru this winter....that was a surprise. The rear flairs MUST get attention this spring as well.
but the drive line is excellent, and the truck only has 66,000 ORIG miles on it!!!
CW
