87 short bed with a full 99 swap El Paso Texas
KCsurfer420
I'm thinking about selling mj 99 swaped mj. I bought it 3 years ago as a rust free south west shell. it had no motor or trans when I got it but it was a 2.5 5 speed 2wd truck from the factory.
I bought a rolled 99 jeep xj and swaped every thing over.
The motor was rebuilt at 132 miles on the odometer that is currently in the truck with .20 over pistons, also has a melling HV  oil pump and a eddelebrock 00/01 header and the 00 down pipe. Also has a flow master muffler on a 2.5 exhaust. The trans is an external slave ax15 that has a new luk clutch kit and the oil in the trans was just changed again last saturday. It also has a np  231 case that I rebuilt with the chevy chain and gears with all new bearings. Has a d 30 front with the xj v8 steering and a cryco 8.25 with a Austin locker in it and both axles have 3.55 gearing. No check engine lights or codes.. Every thing works as it should.
Has a 6.5 lift, re adj track bar, fixed lower arms, adjustable upper arms, IRO 6.5 coils, re sway bar discos and precompiled white body shocks as all 4 corners. Rear is a soa. Had old style 33" MTR's on 15" soft 8 rims tires have 50 to 60% all the way around...
Interior has the correct 2 door xj window switch, factory 01 heated leather seats and an aggate interior. Also has the limited wood grain door panels and center panel.
All of the body panes are oem mopar panels not cheap Chinese repops
Needs:
Front drive shaft made,
Passages window rolls down on ds side but not ps side. May be the switch.
I have all of the ac parts for the tuck minus the dryer but none of it is installed.
Interior panels were tan before and painted with SEM aggate paint. Matches nicely but is coming off the panels at the door thresholds.
Missing the b pillar lights
Needs a good paint job and bumpers
I'd like to get 6500$ for it
Located in El Paso tx.
Can possibly deliver for 1.00$ a mile
If interested please call me
Tim 915 920 9690
df06042d9c332c873f111742dd5f1de1.jpga9016f22170f4e8764b1e485f79aa7d0.jpgd1b8cc94324c85725fffac8f41874a74.jpgd63f878cceacbbd1f9861121a7026797.jpg45e7e29f52a750577e7387b28d20c591.jpg4b6a120fc483bf07cc3e1dc5cb5c171e.jpg66b83537fbab83ab54fafed729450491.jpge9cb0184bd025b96b0fdfa0c6c233967.jpg244266856f88905a7ca0d26c9c07fdfc.jpg5857cd8ad1faaec0ef0494e355091bc5.jpg
  • 4 months later...
Archived
