89 MJ oil leak where the motor meets the tranny
Hey gents,
just bought an 89 MJ 4x4 stick with the 4.0, and have noticed a slight leak of oil coming from right where the motor meets the transmission, I haven't had a whole lot of time to look at it and make sure its not dripping down from somewhere else but ill do that today, any thoughts on what it could be or something I can use to fix it?
Thanks in advance!
Stu
check out cruisers tips in the DIY section. Assuming you're meaining between the motor and the bell housing. It could be the valve cover gasket, oil filter adapter seals, or possibly the rear main. I would wipe everything off and start looking from the top down.
