1990 Comanche LWB Expedition style build
I just picked up my 1990 2wd 4.0 long box Comanche two weeks ago and I'm getting ready to start building it. I've owned quite a few jeeps over the years, but its been about 3 years since of had a built jeep. My main purpose for this jeep is to get to remote hunting and fishing spots in the foothills and mountains, while still being able to haul a jetski in the bed and pull a jetski trailer.
Plans
Keep the Renix 4.0L and swap in a AW4 with NP231 tcase
HP dana 30 with wj knuckles and brake, 4.56 gears
Dana 44 rear with disc brakes, 4.56 gears and locker
4.5" lift (haven't decided on long arms or drop brackets)
Hybrid cage with a bed rack
Lots of lights
35" tires
Iceland offroad flares
Lots of armor
98+ front clip
Paint silver or olive drab to match my 1947 willys
Here's how the comanche looks the day I got it
I'll get some better pictures when it gets back from the exhaust shop tomorrow, it's getting full 2.5" exhaust with a super 50 muffler.
I've started designing my hybrid cage with a bed rack, but I'm struggling with having the two flow nicely together. I'm not really happy with what I have now and am open to suggestions! I don't want the bed rack to sit above the roofline, I hated my roof rack on my 4door xj. I also want to make sure there's nothing overhead in the last few feet of the box so I can easily hop in the box and load a jetski.
No major update, but took care of a few things over the weekend.
Went to the wrecker and pulled the oilfilter adapter out of a HO cherokee and installed it in my Comanche. I also replaced the wheel cylinders in the Dana 44 and replaced the front shocks to pass inspection
One of the local car audio shops was liquidating there 2014 stock and I picked up some demo units cheap. The Comanche only had one working 6.5" speaker in it and CD player barely worked.
So for around $400 I was able to pick up a jcv bluetooth headunit, kenwood 5 channel amp, kicker sub with box and 4 alpine speakers.
I'm working at a chrysler dealership in stony. I am actually looking at building the same kind of truck you are planning same size tires with the same style of rack/exo cage only a little more simple but all in all the same set up. With the same type of truck only a year older. old my wife about it last night and we shared a good laugh.
  • 7 months later...
I finally started on this build, as I was too busy building standup jet ski's all summer. I've order most of the parts I need now and picked up a 4wd parts Comanche
Here's what I have now
BDS Long arm builders kit
4.5" BDS coils
4.56 gears and an ARB locker for the Dana 44
HP Dana 30 with WJ knuckles 4.56 gears and a trutrack
Ruff Stuff 1 ton cross over steering with offset tie rods
35" MTR kevlars
Smittybilt XRC suspension seats
Smittybilt XRC 9 comp winch
Iceland offroad style flares
Here's the 1989 base 4.0L 4wd comanche, the driveline was in really good shape minus a bad rear pinion bearing in the dana 35. I've already swapped the 4wd tranny and transfer case and I'll finish the 4wd conversion when I build the Dana 30
While I've been waiting on the parts to come in, I started gutting the interior. The rot wasn't too bad, I only had to replace some of the floor on the drivers side.
Carpets out
Drivers side rust
Cut into the floor to inspect the unit rail, it was surprisingly clean, so I just coated it with POR15
I didn't take any pictures of the driverside floor repair, but here's the floors after a couple coats of POR15. The carpet will be cleaned up and dyed black
Started working on the 97+ front clip and door swap. I found a 2000 XJ with power doors at pick n pull, the front clip, driverside fender and doors were all in great shape. I had to wait a few weeks to find a decent passenger side fender.
Striping the MJ
Installing the doors and swaping over the lock cylinders
Rather them welding the new door striker plates on, I opened up the top bolt hole with a carbide burr and found a bolt that would replace the old door striker pin. That way I could bolt the striker and adjust the doors easier.
Doors and front clip installed
