summerinmaine Posted May 13, 2007 Share Posted May 13, 2007 Anyone have a pic or a diagram of the assembly? My MJ came without a pedal, so I'm stepping on the bare lever rod (I've heard it called the "skinny pedal" but this is ridiculous), and there is no obvious way to attach a pedal to mine. Do I need to replace the entire lever rod with a new pedal? TIA for any advice. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted May 13, 2007 Share Posted May 13, 2007 it's held onto the firewall by two bolts, and a clip for the cable. replace the entire assembly...it would be less than 5 bucks from a junkyard Link to comment Share on other sites More sharing options...
summerinmaine Posted May 13, 2007 Author Share Posted May 13, 2007 it's held onto the firewall by two bolts, and a clip for the cable. replace the entire assembly...it would be less than 5 bucks from a junkyard Thanks. So I take it that the pedal is welded or otherwise affixed to the lever rod? Link to comment Share on other sites More sharing options...
JeepcoMJ Posted May 13, 2007 Share Posted May 13, 2007 with a spring and a clip thing. it's just simply easier to replace the whole thing. Link to comment Share on other sites More sharing options...
summerinmaine Posted May 14, 2007 Author Share Posted May 14, 2007 Thanks. Link to comment Share on other sites More sharing options...
