comancheon33 Posted January 31, 2006 Share Posted January 31, 2006 I am adjusting my new TNT longarm kit. For a reference I am looking for the stock wheelbase for a MJ shortbox. If someone knows this I would like to know. Thanks in advance, Dustin Link to comment Share on other sites More sharing options...
pingpong Posted January 31, 2006 Share Posted January 31, 2006 I wanna say it is around 113, I know the LWB is 119.3 or something. If I was you... I would set it so my tires are centered in the wheel well, instead of worrying about the proper wheel base. Remember if you flex out, your tires will travel closer to the cab. Or this is what I have learned. don't ofr get to set you caster to factory specs as well, then worry about your pinion angle. Patrick Link to comment Share on other sites More sharing options...
Xacto Posted January 31, 2006 Share Posted January 31, 2006 Manual says 112.9" for the shortbed 4WD. Link to comment Share on other sites More sharing options...
comancheon33 Posted January 31, 2006 Author Share Posted January 31, 2006 I am planning on centering it in the wells. I just wanted a ough idea on where to roughly start from. Thanks for the info so far. I am hoping to find a happy medium between caster and pinion angles. It will be one big experiment for a while. Link to comment Share on other sites More sharing options...
pingpong Posted February 1, 2006 Share Posted February 1, 2006 I think with mine I set My wheel base at 122 and my pinion was at 7*. that gave me the best trcking ability going down the road. patrick Link to comment Share on other sites More sharing options...
