combatcamera Posted June 17, 2014 Share Posted June 17, 2014 Hi, A few quick questions about things going on my with my '89 Comanche. 1. When running, the voltmeter reads just under 12 volts. Just started doing this recently. The alternator is brand new as is the battery, so I know it's not that. Not a lot to go on, but I'm largely clueless when it comes to electrical items. Any idea where the drain may be? 2. Lke many other Comanches, the floor pans on mine, well, need replacing. I've never welded anything and I don't have a welder anyway. I'm curious if there is anybody in the Maryland area that could help out with welding in floor pans. I'd compensate you for you time of course. Just would prefer doing it this way than taking it in to a body shop of some other similar place. Thanks. Jon Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 18, 2014 Share Posted June 18, 2014 Measure what the charging voltage is directly across the battery posts. Also clean up all your mains cable terminations and ground points. Link to comment Share on other sites More sharing options...
