Hey, so looking through the forums, everyone is very concerned with the master cylinder leaking onto the fuse box. Well, this happened to me.  A year or so ago, i caught the leak and swapped out the master cylinder and even replaced the clutch because of a leak on that too. The leaking fluid has corroded some of the fuses, and as a result, my brake lights, and turn signals fail to work sometimes. a quick little tap and  some finesse with the fuses makes everything work again, but the problem is becoming more and more reoccurring. so, whats the fix for this? new fuse box? where can i get one?
BTW i drive an 89 Eliminator. 80,000 miles as of today
