RavenMocker Posted January 31, 2014 Share Posted January 31, 2014 Is there anything special that I should keep from cutting up and modifying on the interior of my 1986 MJ? I mean its just the basic interior with a bench seat. I will be going to bucket seats and also wanted to modify the gauges to my own needs. Such as a tach for the cummins L6 I will be installing. I thought about taking out the stock instrument cluster and modifying it with other gauges and faces to match and try to make it look stock. But I was not certain if that instrument cluster was only in the MJ's. Anyway I just don't want to destroy something that might be hard to find that someone else might need. Link to comment Share on other sites More sharing options...
MJ_Milam Posted January 31, 2014 Share Posted January 31, 2014 as far as i know, the clusters in the MJ's are the same as in the XJ's. i swapped my idiot light cluster out for a full gauge cluster which i pulled from an XJ in a junk yard but u can always put old parts on the internet and make a few bucks to put towards your build Link to comment Share on other sites More sharing options...
FrankTheDog Posted January 31, 2014 Share Posted January 31, 2014 Your going to put a 6BT in it? Are you going to stretch the nose or are you going to put a dog house in it like a van? What do you plan to do with the front suspension. You can find gauges out of similar year Cherokee's if you want to cut up a gauge without ruining yours first. OK, read your other post, 6AT cummins. I'm not familiar with them. Link to comment Share on other sites More sharing options...
