88 Mj Engine Swap To 97?
i have a 88 mj 4x2 4.0 the rings are shot and I'm looking to swap in something fairly quick and then rebuild the motor i have and make it a stroker and all that later as i have the money. i did find a 97 grand charakee with a 4.0 auto. i was talking to a local guy and he said the exahust won't line up and the crank position sensor needs to be switched. i was wondering if anyone knew of anything else that needs to be changed. any other info would be great also.
also i would like to convert this to 4x4 using the better ax15 and a 231. any advice on this?
