i have a 87 mj with a 6"  short arm lift  w/ sbc when i hit a bump/ snow banks or even some rr crossing i get a loud clunk on the left front all the ball joint, sway bar, control arms, steering is tight. if any one has an idea i would like to hear it.
Look for any simple interferences, metal to metal will leave a witness mark in the paint or rust. Sway bar, coil springs, track bar contact at frame end. You may need to adjust the track bar longer to move the axle back to center. Just throwing out some ideas.
