SwayAwayComanche Posted November 20, 2013 Share Posted November 20, 2013 I have a very good running comanche but I also have a spare Ho motor laying around and have parted many cherokees out so I have all HO parts at my disposale. My renix lower end was just rebuilt but the head was not gone through and is due. With that being said i would like to use the ho head,header,TB and 99 manifold on my RENIX BLOCK is this possible? other questions I have are.. I know I also need to adress the fuel lines and swap all sensors to the 99+ intake and figure out how to get my fuel gauge working right, any other possible snags? can the renix injectors and fuel rail be retained or do you have to switch too a ho fuel rail? being a higher fuel pressure and different return seems like alot of hassle when using the TPS adapter do you still set it to the same Renix specs? Thank you for the help in adavance and if there is any other kind of guidance you can give me it would be greatley appreciated Link to comment Share on other sites More sharing options...
