Guest Posted November 9, 2013 Posted November 9, 2013 Finally decided to sell my 1989 Jeep Comanche. $3000 OBO cash only.4.0L ~145500 miles5spd AX-15 manual transmission4x4 w/ NP231 transfer caseDana 35 front and 44 rearThe following work has been done in approx. the last 6 months:New brakes, rotors, drums, and calipers. New water pump, belt, tensioner and idler pulleys. New rear main seal, felpro oil pan gasket, valve cover gasket. Have a new head gasket that will come with the truck (purchased it, but didn't need to be replaced). All new vacuum lines and bracketsNew direct fill radiator and heater control valve with all new coolant hoses. New ball joints will come with the car if I don't get a chance to replace them before it sells.K&N air filter.Currently setup with AC but needs recharged. A Renix AC delete pully will come with the truck if desired.New headlightsNew clutch, throw out bearing and slave cylinderNew throttle body gasketNew fuel filter fresh oil change and filterTransmission flush and refillNew differential gaskets and gear oilNew differential drain plugsReplaced bucket seats with a bench seatNew AC condenser will come with truck if you wish to keep the AC.Multiple new fuses and new flashersNew down pipe, exhaust piping to cherry bomb exhaust 3" lift using spring spaces and new longer shackles. New rancho shocks and bushingsClean interior with only a few things like the interior light covers that are broken. Seat moves forward and back and leans forward with no problems.Heat, radio (will be putting in an aftermarket Kenwood head unit soon or will come with truck)New plugs, wires, and distributorNew crank position sensorCat deleteNew e-brake cablesAdded tool box in bedSure there are many new parts just can't remember them all.Doors have vent windows and windows roll up and down easily. Rear window has double sliding window.The problems:Has a wobble at approx. 55MPH.There is body damage around the drivers side tail light. Rear bumper has rust and is damaged.Drivers door has rust near the bottom. Very few things left to fix or replace at this point. Overall, a great running truck and fun to drive!If you're interested in coming to take a look just text me or call at 734.812.3716. I can be free just about any time to show it.ThanksLocated at 7 council drive, woodsboro, md 21798 at The SHOP Autowerx.
Guest Posted November 10, 2013 Posted November 10, 2013 Howdy, I would like to see ur Jeep if u still have it. I live in Maryland during the week. Contact me at this address. billydixon50@gmail.com Thanks Steve
Archived
