VermontMJ Posted August 7, 2013 Posted August 7, 2013 I have a 1987 Comanche I am working on building. I found a parts list I am working on and want to make sure it will all work together. This is my first mj build of hopefully several. As I bought the truck it has a stock 4.0 with the ba10 transmission transfer case unknown. The axles are not original they are Dana 44s from ????. It has I think at least a six inch lift now with coil overs and 35 inch super swampers. Ok now for my question... I would like to know if my parts list is going to work with too much major fabrication and if anyone has reasonable suggestions for improvement. The parts list: Atk 4.7 inline six stroker engine AX-15 transmission NP-231 transfer case Disc brake conversion kit Flowmaster exhaust Dick cepek mud country tires Dick cepek wheels Warn front bumper and winch Rhino bed liner The parts i am looking for suggestions: Intake Water pump and cooling system Ignition system Steering stabilizer and front end Sway bars and sway bar disconnects Front and rear lockers Other heavy duty drivetrain pieces Air system Skid plate setup Rear bumper and roll bars Lighting Any other suggestions Now keep in mind although I would like high torque off road capability I want to keep daily driver use. Any help with this is appreciated pictures coming soon
