Frankensteinsmj Posted March 30, 2007 Share Posted March 30, 2007 I'd be very grateful if someone has a FSM on a 88 4.0 5 speed manche. I need to have someone take a quick look at the TPS setting info for me. TIA Frank Link to comment Share on other sites More sharing options...
mjeff87 Posted March 30, 2007 Share Posted March 30, 2007 From the 88 FSM (lemme know if you need anything else): THROTTLE POSITION SENSOR (TPS) 1) Turn ignition on. Check throttle position sensor input voltage. Connect voltmeter negative lead to terminal "B" (M/T), or terminal "D" (A/T) of sensor connector. Connect voltmeter positive lead to terminal "A" (M/T and A/T) of sensor connector. NOTE: On (A/T) models, connector terminals are identified by letters molded into back of connector. On all models, do not disconnect TPS harness connector. Insert voltmeter test leads through back of wire harness connector. On some models, it may be necessary to remove throttle body from intake manifold to gain access to sensor wire harness. 2) Move and close throttle plate completely (M/T and A/T). Ensure throttle linkage contacts stop. Note voltmeter reading. Input voltage at terminals "B" and "A" (M/T), or terminals "A" and "D" (A/T) should be 5 volts. 3) Return throttle plate to closed throttle position (M/T and A/T). Check sensor output voltage. To do so, disconnect voltmeter positive lead from terminal "A" and connect it to terminal "C" (M/T), or terminal "B" (A/T). 4) Maintain throttle plate in closed position (M/T and A/T). Ensure throttle linkage contacts stop. Note voltmeter reading. Output voltage should be .8 volt (M/T), or 4.2 volts (A/T). 5) If output voltage is incorrect, loosen bottom sensor retaining screw and pivot sensor in adjustment slot for a coarse adjustment. Loosen top sensor retaining screw for fine adjustments. Tighten screws after adjustment. Link to comment Share on other sites More sharing options...
Frankensteinsmj Posted March 30, 2007 Author Share Posted March 30, 2007 mjeff, thanks, I have a m/t and my chilton's procedure is about the same. When I set it to .8 volts and start it the engine rev's really high so I don't know what's up with that. If I bump it down to about 7.5 volts it idles out ok. If you know anything about this let me know. thanks, Frank Link to comment Share on other sites More sharing options...
JohnQ Posted April 5, 2007 Share Posted April 5, 2007 I bought a brand new one and just threw it on. I wonder if I have adjusted right? Link to comment Share on other sites More sharing options...
87manche Posted April 5, 2007 Share Posted April 5, 2007 mjeff, thanks, I have a m/t and my chilton's procedure is about the same.When I set it to .8 volts and start it the engine rev's really high so I don't know what's up with that. If I bump it down to about 7.5 volts it idles out ok. If you know anything about this let me know. thanks, Frank check the grounds, and check that what the TPS is seeing at the connector is what the ECU is putting out. The TPS get's it's power from the ECU, the ECU monitors what it puts out, then compares that to what it gets back. A poor connection/corrosion would throw off that reading. Link to comment Share on other sites More sharing options...
