i have an 88 jeep comanche with a 2.5 amc. when the engine is warm after driving like 1 hour or so if i pop the hood there is a hissing and somthing leaking out around where the intake manifold is i am not sure but i think its a bad intake manifold gasket??
I don't think just the heat from the ex manifold will ignite starter fluid. However a red hot piece of carbon blowing out will. Ask me how I know.
Get a can of starting fluid and spray it around the intake manifold. If the engine speeds up that's where the leak is.
Then just do it when the engine is cold.
