Cherokee A/c Hoses For Comanche?
Hi everyone.
I am intending on rebuilding my A/C from the ground up.  Truck: '87 comanche, 2.5L, 2WD, 4 speed.
From other posts I discovered a 94-96 Cherokee system is "bolt in" and is R134 native.  However, I looked on autopartswherehouse and they only list hoses for the Cherokee 4.0L sport.  None for 2.5L or other models 4.0L models for that matter.
Are the hoses the same?  Where do you buy your hoses?  I don't want to buy hose "kits" since I don't have a crimper, Id rather just buy the factory hoses.
The 4.0L and 2.5L A/C hoses are not the same. Below are the correct part numbers for your 2.5L if it has factory A/C. You can probably cross the part numbers.
56001781, HOSE, Evaporator to Compressor, w/o Muffler
56002950, HOSE, Evaporator to Compressor, w/Muffler
56002196, HOSE, Receiver to Evaporator
