Overbuilt 86 Comanche
Picked up an 1986 Comanche LWB. Going to run everything from my old xj on it which will take some modifying and coercion on some parts. The xj has lots of rust/holes that just aren't worth the hassle when I picked up this comanche for $400 with the only trace of rust under the carpet but its only superficial.
The plans are to run my TNT Y-Link that have MetalCloaks new Duroflex Joints at the frame end of the LCA's
Rear 44 trussed with 4.56
Front LP 30
Fox 2.0s all around
Caging and stiffening the frame bumper to bumper. Cage will be hybrid.
I then pulled the interior and every wire out awaiting my swap.
I want this thing to last me a while so I'm plating and caging this bad boy
This is for under the cab area
309879_663956189613_1315538278_n.jpgcage progress
Some inner frame plating after the stock control arm brackets have been removed.
421444_671597221923_911781254_n.jpgMore
24287_671596692983_220363555_n.jpgGot some outer plates from Liquid Iron Industries. Great Vendor
Ill be tying the plates together underneath in key places for more strength.
Threw these shocks in for now. Going to run them through the bed eventually
So I just moved back from CO to UT and I have no garage now so progress will be slower. Its running and itll be registered soon. I need to finish my passenger side rock rail to tie my cage into and I have lots of other goodies thatll be added on.  Hope you guys like it
  • 6 months later...
Updates
Well i had my buddy cory finish weld my rocker panels on and also finished the cage.
The rockers are made out of 1.5"x3" 3/16 wall steel with 4, 1.5" DOM tie ins to the frame and some tube flanges used to increase the weld area.
2 6" welds and a 9" weld connecting the rocker to the cab, the rocker is NOT welded to the bed so it is still removable
frame tie ins,
cage tied into the rocker
also built a headache rack and i will be adding an actual mount for my spare tire.
Cut and folded the rear wheel wells, don't mind the paint i usually just throw some paint on it to keep it from surface rust
Looking to make some tube fenders too, like ericsxj but a bit wider for legality
