Brake Lines From A Jeep Rear Axle To 8.8
I used two r/side Explorer lines, fabbed hard lines, connected to Dakota axle to frame line.
My friend used both stock Explorer lines hooked to a dropped bracket with the Explorer to frame line.
Actually, the stock left side Explorer line runs from the caliper to an axle bracket, where the right side line ties into it, then up to the frame , all one piece.
Then it ties into hard line to the right side, then short rubber line.
It's doable using the stock Explorer line, but I didn't.
Either way, your doing an 8.8, the brake lines are definitely the easy part.
