At Junkyard, 4X4 Conversion Question
I ended up taking the fuse box and wiring harness from this truck yesterday. Now I'm wondering if I should go back for all the 4wd parts except for the tranny since it has such low miles. Will the 2.8L stuff work on my 2.5L?
Grab the front axle if it matches your rear.
I don't think all the linkages will help you, especially depending on what 4wd system that 2.8's got.
I don't think the T-case will help you, I seem to recall the 2.8's automatic having a 23 spline output. All AX-4/5s are 21 spline.
