kdjdhdjd Posted December 28, 2012 Share Posted December 28, 2012 86 comanche v6 carborated I made made into a offroad when I bounce the front end hard off the ground three or more times I have to pump throttle to keep running some times it starts to run good right away and some times it takes awhile any ideas ? And also what do I need to do to make the front land soft when jumpping ? Link to comment Share on other sites More sharing options...
87Warrior Posted December 29, 2012 Share Posted December 29, 2012 Sounds like the carb is flooding. There are some aftermarket carbed designed to work better at extreme angles. I am unsure of their compatibility with the V6. Hydraulic bumpstops. Example: www.kingshocks.com/category/products/bumpstops/ Example: store.jksmfg.com/merchant2/merchant.mvc?Screen=BUMPSHOCKS&Store_Code=JKS01&Category_Code=Coil_Spring Best advise: Don't jump a stock MJ. Link to comment Share on other sites More sharing options...
