89 mj project ?
Looking for pointers on unibody reinforcement for a through cab cage and will be linked up front and rear with either portals or rockwells . Anything that needs to be addressed? Other things to consider? So...... GO
thanks
-Harlem
rubicon express and some others make frame stiffeners that go across between the front at the steering and trackbar and stuff. might try one of those.
portals are pretty serious axles... you might wanna just get some steel and go all the way down the frame beefening?
i would search naxja.org I'm sure someone over there has mogs on their truck and can give some pointers at least on stiffening the front end.
