89Comanche4x4 Posted October 22, 2012 Share Posted October 22, 2012 Hi i have the opportunity to grab a liberty light bar for $250 do they fit on the comanche? i have seen one on a truck here and would like to know how they mount on the roof and what kind of wiring i need to do. thanks Link to comment Share on other sites More sharing options...
Dadinator Posted October 22, 2012 Share Posted October 22, 2012 Sounds like a good deal if it works. No personal experience, but I've seen them on a couple of MJ's on here. Good Luck! Link to comment Share on other sites More sharing options...
Automan2164 Posted October 23, 2012 Share Posted October 23, 2012 Drilling holes is almost more than certain. Once you can accept that, it's all down hill. Rob Link to comment Share on other sites More sharing options...
Backdraft Posted October 23, 2012 Share Posted October 23, 2012 They will fit if you make them. The edges will not sit perfectly flat against the roof but it's close enough. There will be about 7 holes you need to drill in the roof for the mounting points and the wiring harness. If you get it, try to get the harness for it as well, it will make wiring less painful. I have one for my phoenix build and will be mounting/drilling the holes/wiring it up in about two weeks when I take vacation. Link to comment Share on other sites More sharing options...
