Feeler: XJ/MJ Novak Adapters Chevy Engine Mounts (NJ)
Garvin
Throwing a feeler out there for these (not so much a feeler but an early for sale kinda thing if that makes sense). I'm looking at building a set of custom mounts to fit all the custom work I've done to the Jeep better (need to raise the front of the engine a bit more since my trans has been raised a good bit) so my current mounts are up for sale.
The mounts is a set of Novak Adapters for Generation I & II small block Chevy engines ('55-'98). The mounts have been modified slightly to fit better. The passenger side mount had a little more cut out of it so that the engine would drop in with a lot less hassle (it's a REAL tight fit a royal pain without that cut out a little more). The rear of the drivers side engine side had a little chunk of the back cut out in order to clear the Sanderson headers better. The drivers side frame mount had three holes egged out slightly so that the mount actually does fit '84-'86 engine bays as well as the '87+ engine bays.
The mounts new are $218, I'm looking to get $150 + shipping for them. Link below to the Novak page. I will accept paypal but it either needs to be sent as a gift or you must pay for the fees. These are located in Wrightstown, NJ.
http://www.novak-adapt.com/catalog/engi ... /mmxj1.htm
The mounts will be removed in a week or two or after someone throws the switch on them (must leave a deposit if you want me to remove them right away). I have this posted on multiple forums and will be getting back to people in the order they post or message me in.
Archived
