luvmyglock Posted July 4, 2012 Posted July 4, 2012 So I am having some odd problems after reinstalling my fuse box and reinstalling my interior (did my floors and had to take it out to get the rust away from it). When the parking brake is on, the brake light is off. When I release the brake, it comes on. Also, the headlight knob works fine to pull to turn on the lights, but when I turn it clockwise to turn on the gauges it dims them instead of intensifying them...it's like everything is backwards! Also, I lost my chime somehow at the same time.. I can't figure out what happened here...
Garvin Posted July 6, 2012 Posted July 6, 2012 That's a weird one...The best advice I can give you there is to check down everything you had disconnected and make sure they aren't on backwards. Also make sure the door switch is plugged in (the little push button switch that is pushed in when the door is closed and out when it's open), that could cause your chime to disappear.
