bigredjeep1 Posted June 5, 2012 Posted June 5, 2012 http://chicago.craigslist.org/nwc/cto/3058696326.html 1987 Jeep Comanche long bed for sale with 4.0L fuel injected 6 cylinder motor, AW4 automatic trans with overdrive, 231 command trac t-case, HP dana 44 front axle, Ford 9" rear axle with 8" lift. 1987 Jeep Comanche long bed for sale. It has a 8 inch lift using rubicon express coil with a front radius arm type suspension and bastard pack leaf springs in the rear using the mj pack with a few xj leaves. The radius arms are built using 2" x .25" square tubing and ruff stuff 1.25" hiems. Front track bar is also built with 3/4" hiems and 1.5" x .25" wall DOM tubing and ruff stuff brackets. Rear is installed using Ruff stuff spring perches and spring plates. Front axle is a 79 ford high pinion Dana 44 with 4:10 gears and brand new Warn lock out hubs and rear is a 79 ford 9 inch with 4:10 gears. IJeep has a H.O. 4.0 liter straight six from a 92 cherokee running off of the factory renix fuel system. Has an AW4 trans with a NP231 transfercase. Gauges have been replaced with aftermarket Fuel level, Volt, Oil pressure, and coolant Temp gauges and has LED high beam and turn indicators. Has almost brand new 35/12.50/15 Pro Comp MT's on a set of steel wagon spoke wheels. Jeep was used mainly as an offroad toy but can be driven to and from the trails and/or daily driven as I am now. Body is a little rough but that is to be expected with a trail rig. Unibody is solid with no cracks and door hinges have been modified for easy removal. Asking $3,500 Located in Roscoe, IL off I-90 along IL/WI border (just south of Beloit, WI and 15 min north of Rockford, IL) Troy 815 222 nine four 0 nine
bigredjeep1 Posted June 11, 2012 Author Posted June 11, 2012 $3500 OBO Now has worn 33" SS Truxus MTs, stock steering, no rear bumper, but has a double tube front bumper. text me at 815 222 nine four 0 nine and/or troystein@gmail.com for more info and pics thanks Troy
bigredjeep1 Posted June 13, 2012 Author Posted June 13, 2012 $2500 OBO Now has worn 33" SS Truxus MTs, stock steering, no rear bumper, but has a double tube front bumper. text me at 815 222 nine four 0 nine and/or troystein@gmail.com for more info and pics thanks Troy http://chicago.craigslist.org/nwc/cto/3058696326.html
bigredjeep1 Posted June 15, 2012 Author Posted June 15, 2012 Updated pics and info: http://chicago.craigslist.org/nwc/cto/3075060149.html 1987 Jeep Comanche long bed for sale with 4.0L fuel injected 6 cylinder motor, AW4 automatic trans with overdrive, 231 command trac t-case, HP dana 44 front axle, Ford 9" rear axle with 6" lift. 6" RE express coil with a front radius arm type suspension and bastard pack leaf springs in the rear using the mj pack with a few xj leaves. The radius arms are built using 2" x .25" square tubing and ruff stuff 1.25" hiems. Front axle is a 79 ford high pinion Dana 44 with 4:10 gears and brand new Warn lock out hubs and rear is a 79 ford 9 inch with 4:10 gears. Jeep has a H.O. 4.0 liter straight six from a 92 cherokee running off of the factory renix fuel system. Has an AW4 trans with a NP231 transfercase. Gauges have been replaced with aftermarket Fuel level, Volt, Oil pressure, and coolant Temp gauges and has LED high beam and turn indicators. Jeep was used mainly as an offroad toy but can be driven to and from the trails and/or daily driven as I am now. Body is a little rough but that is to be expected with a trail rig. Unibody is solid with no cracks and door hinges have been modified for easy removal. Asking $2,800 Located in Roscoe, IL off I-90 along IL/WI border (just south of Beloit, WI and 15 min north of Rockford, IL) Troy 815 222 nine four 0 nine
bigredjeep1 Posted July 2, 2012 Author Posted July 2, 2012 $2700 OBO has nice 35" PC MTs on it with little wear on them. front double tube bumper, no rear bumper, stock steering for the front dana HP44.
bigredjeep1 Posted July 5, 2012 Author Posted July 5, 2012 $2600 FIRM with good 35" PC MTs, $2000 with roller tires/rims. http://chicago.craigslist.org/nwc/cto/3116787574.html Added a front double tube bumper and pirated the rear bumper for my other MJ.
bigredjeep1 Posted July 16, 2012 Author Posted July 16, 2012 Parting out my 87' MJ: Nice dana full width dana HP44 & Ford 9" axles with ford radius/Ruff Stuff heavy duty long arms with heim end (3 link long arm)...will include the frame end bracket mount so you can weld them up and bolt into a MJ....or a XJ with a little work (rear spring perches are different then XJ I hear) but same SOA setup. $2000 OBO on the pair of axles with stock HP44 steering, long arms, Ruff Stuff double adj track bar ($270 new), also newer 6" Rubicon Express coil springs....so this is a plug and play upgrade for someone. I wish I had this setup on Big Red in my avatar pic years ago on the Rubicon instead of weld on RE suspension system for the HP44 and then running their drop brackets and adj short arms...cost way too much $ doing it like that and still not having long arms. Dana HP44 front axle with 4.10 gears and lincoln locked and newer Warn hubs Ford 9" rear axle with 4.10 gears and limited slip and drum brakes both 5 on 5.5 Troy 815 222 nine four 0 nine Located in Roscoe, IL 61073
bigredjeep1 Posted August 3, 2012 Author Posted August 3, 2012 $1000 not a penny less on roller tires/rims
Archived
