creekscout Posted May 4, 2012 Share Posted May 4, 2012 I want to replace the shocks on my 92 metric ton mj with 1 3/4" front lift, stock rear. I would like to know if the metric ton had the same rear shocks as standard trucks? Also what shock size do I need for the front if the distance between the axle mount and fenderwell hole is 20"? Thank You for any help Link to comment Share on other sites More sharing options...
