jk springs on comanche
The front JK springs will work, but are about the same length as stock XJ springs. the rate might be a bit higher which might give a small amount of lift, but I'm not sure that it would be worth the trouble.I was going to do this on my donor parts truck when I put the front axle back in, but as the springs were about the same size, I didnt see the point too much and decided against it.
