86 Waggy XJ
Guest
don't wanna do this, but I'm getting ready for college early. gotta let my beloved waggy go. LOCATED IN HARLEYSVILLE, PA 19438
1986 Jeep Cherokee Wagoneer
THE GOOD:
New 2.8L Engine
Rebuilt carb
Rebuilt transmission (TF904)
added transmission cooler
professionally installed 3" lift (full leafs, teraflex upper control arms, skyjacker lowers)
15x8 Dick Cepek DC1s
31x10.5R15 Mastercraft All-Terrians (75%+ tread)
regeared to 4.10s (d30/d35)
axles rebuilt to
new exhaust from manifold back
new starter relay
new EGR valve
deep cycle battery
k n filter
new track bar
new steering stabilizer
new cross drilled slotted rotors/new pads
new calipers
new brake hose
new rear brake shoes+hardware+wheel cylinder
new ebrake cable
new A-pillar lights color matched
new hatch struts
removable doors
chrome diamond plate fuel door
passed PA inspection/emissions without a hitch!
painted floors
~15mpg (seen as high as 18.5, as low as 12)
18X,XXX on body, around 20k engine/trans/transfer case (need to find paperwork)
very little underside surface rust for its age and I'm 2nd owner (aunt+uncle owner 1st)
THE BAD:
could use bodywork here and there.
front pass. door is dented a bit
fiberglass hatch is cracked (don't bother it from closing)
front where "Jeep" is, is fractured some. easy fix
front drivers fender flare is peeling some
missing logos (working on that now)
rear bumper mount is busted (working on new one+shiny new chrome bumper)
front drivers side endcap gone (working on that too.
looking for $4k or trade for comanche + $2k or so. have $8k or so in reciepts
clean pa title
323501_10150545995724450_852559449_8583749_1916659136_o
373773_10150503144359450_852559449_8443522_1217858103_n
332686_10150514801154450_852559449_8484542_1482368468_o
http://www.flickr.com/photos/51977521@N06/6858227457/
Archived
