Guest Posted January 26, 2012 Share Posted January 26, 2012 1987 Jeep Comanche long bed for sale. It has a 6 inch lift using rubicon express coil with a front radius arm type suspension and bastard pack leaf springs in the rear using the mj pack with a few xj leaves. The radius arms are built using 2" x .25" square tubing and ruff stuff 1.25" hiems. All new steering linkage built with 1.5" x .25" wall DOM tubing and 3/4" and 7/8" hiem joints. Front track bar is also built with 3/4" hiems and 1.5" x .25" wall DOM tubing and ruff stuff brackets. Rear is installed using Ruff stuff spring perches and spring plates. Front axle is a 79 ford high pinion Dana 44 with 4:10 gears and brand new Warn lock out hubs and rear is a 79 ford 9 inch with 4:10 gears. I do have a set of 5:13 gears for both the front and rear axle that will go with the jeep. Jeep has a H.O. 4.0 liter straight six from a 92 cherokee running off of the factory renix fuel system. Has an AW4 trans with a NP231 transfercase. Gauges have been replaced with aftermarket Fuel level, Volt, Oil pressure, and coolant Temp gauges and has LED high beam and turn indicators. Has a small cobra CB installed. Front bumper is no longer on the jeep but I do still have the 8000 lbs electric winch that will also be included in the sale, was planning on building a stubby winch bumper for it. Has a built rear bumper with hitch reciever built into bumper with more than factory mounting tie-ins and has a flag mount that is required for most off road parks. Has almost brand new 35/12.50/15 Pro Comp MT's on a set of steel wagon spoke wheels. Jeep was used mainly as an offroad toy but can be driven to and from the trails and/or daily driven as I am now. Body is a little rough but that is to be expected with a trail rig. Unibody is solid with no cracks and door hinges have been modified for easy removal. Asking $5000 OBO location: Rockville, IN 47872 [imghttp][/img] Link to comment Share on other sites More sharing options...
Guest Posted January 27, 2012 Share Posted January 27, 2012 I may take partial trade as well, just let me know what you have. Link to comment Share on other sites More sharing options...
Guest Posted January 29, 2012 Share Posted January 29, 2012 Also will consider any reasonable offers, this thing kind of needs to go. Link to comment Share on other sites More sharing options...
Guest Posted February 3, 2012 Share Posted February 3, 2012 anyone? :dunno: Link to comment Share on other sites More sharing options...
Archived
