Built 91 MJ for sale in KY $5400
http://nashville.craigslist.org/cto/2782424303.html
91 Comanche Eliminator
Clean Title
4.0L
AX-15 - 5-speed
NP231 - T-case
AXLES:
Full Width Ford D44 front pushed forward 3", Warn Chromoly Axles, Spicer joints on short side, Stock inner/outer Axle w/ Alloy Xjoint on long side, Detroit EZ locker w/ 4.88 gears, Chevy Flat top knuckles, Blazer spindles, Wagoneer calipers, Ford discs, Mile Marker Lockouts
Full Width Ford 9" pushed forward 8", Chromoly axle shafts, Full Detroit Locker with Tru Hi-9 3rd member w/ 4.88 gears, Ford Drums
ENGINE AREA:
E-350 master cylinder
Cone Filter
Ford "yellow" injectors for better fuel automization
Dual Electric fans (runs 160 deg. on the trails)
STEERING:
PSC Hydraulic Steering kit
DOM steering links with Rod end links
High steer arms
SUSPENSION:
Rear: Comanche Leafs SOA, Frenched hanger into frame
Rancho Shocks
Front: Leaf spring conversion w/ NEW BDS 3.5" YJ springs
rancho shocks
BODY & INTERIOR
Factory bucket seat interior extremely clean
CB Radio with Antenna
Rock sliders
Custom front bumper w/ 9K LB winch & lights
Radiused front fenders reinforced with 1/4 angle iron
Rear of Cab cut out (Walk through) Tube rear section w/ canopy and CJ jump seat mounted in the rear
Ammo cans for storage
Gas tank moved to the rear and up between the frame with a tank skid plate
Lower rack for storage and upper rack for cooler ect.
WHEELS/TIRES
15x8 Crager Soft 8's w/ 4" BS 5on5.5 mounting
36" IROKs balanced with air soft pellets (50% tread left in rear, fronts are about dead)
81" wide in the front
Wheel base is 108"
That's the jist of it, probably a lot I am forgetting. Hydro steer and Hi-9 was over $3900 alone. Rig is very capable. Drives SMOOTH on the highway. Body is not beat up at all. Had it to Harlan through the Lower Rock garden, Damnation, Mason Jar, and other trails. Very impressive reliable rig. Very easy to drive, crawls slow in low-gear and steers easily.
spare parts, axle shafts, ect ect.
$5400.00
606-524-5423
