WA.. axles
cody4359
i have a mj sua 44 with drums, eaton e-locker, yukon 4.56 gears and new wiring harness/switch.
for the front i have a 96' hp dana 30 housing that i just welded C gussets on, havent installed the synergy inner sleeve yet, stock big joint shaft, 4.56 gears, new pinion bearings/carrier bearing and a rebuilt rd100 arb, mini compressor ans locker/compressor switch and harness. as it sits the housing is emptey. will come with brakes etc
$1600 as is
$1900 sleeved and geared
also used set of chromos for the dana30, passanger side has slight twist on splines
Image Not Found
Image Not Found
Archived
