1994 Jeep Cherokee 2WD 2 Door Covington Louisiana
Akula69
OK, the time has come for me to sell this, as I have purchased a 2004 WJ for my daughter.
As the title says, we have for sale a 1994 XJ 2 door. It is green in color with tan interior and has the I6 4.0 H.O. engine. 148K miles. Cryco 8.25 rear, AW4, 2WD. cruise, tilt, full gauges.
We have had this vehicle in our (extended) family since brand new. It runs great and has no serious problems that I am aware of. I use dino oil and mopar filters every 3K miles and have extensive maintenance records. I have done so much work on this critter its hard to list it all, but the highlights ( in the last 3 years) are:
Shocks
UCA
LCA
U joints
Water pump
Radiator (2 core CSF)
Alternator
Blower motor and resistor
A/C Condensor/ Evaporator
Upper/lower hoses
Heater core
Ignition switch
Power steering pump
Power steering hoses
Rear main seal / oil pan gasket (permagasket)
Valve cover gasket (permagasket)
Oil filter adapter O rings
Brakes, rotors and calipers
Pads, drums and cylinders
Axle shafts and seals
Inner door seals
Outer door wipes and exterior seals
Thermostatic fan clutch
New Muffler and catalytic Converter
Temp, oil, speed, TPS, AV control, ECM Temp sensors all replaced
The Good:
Pulls 140 PSI on compression test
Runs like a bat out of h3ll
Dry - no water leaks at all
Clear title in hand
No fluid leaks (other then transmission note below)
Michlin All Terrain tires with 60% tread left
Almost everything replaced!
The Not so good:
Paint (painted in 2008 and flaking in spots)
Driver's side door sags a bit
Bushing in AW4 tailcone needs replaced (seeps transmission fluid - about 1/2 a quart evey 1500 miles)
Cheap carpet
Small crack in lower part of dash.
I am asking 1600.00 FIRM for this jeep, heck - the new parts and tires alone are worth more then that! I will post more pictures later, and will post individual pictures upon request via PM.
Please do not PM me asking for a lower price, if I can't get the value of at least the new parts installed then I'll keep it for parts on the other trucks.
Archived
