turner-2000tj Posted November 7, 2011 Share Posted November 7, 2011 Looking for others opinions concerning installing a fuel cell and an external pump in a 91 MJ. The MJ has 97 XJ running gear but has no fuel system. Due to the conversion the stock MJ fuel system will not work. The popular setup is to use a tank and pump assembly from a Dakota. Since I will be building a trail rig/part time driver I wanted to mount a fuel cell in the bed and then run an exterior pump, something like the E2000. Anyone have any input or experence in doing this? I've read 1000's of posts and tech articles concerning this but thought I'd see if anyone local had any experence with this. Link to comment Share on other sites More sharing options...
deziped Posted November 7, 2011 Share Posted November 7, 2011 That will work, done a couple of such set-ups. You'll have to use a pressure regulator (adjustable preferred) in line to dial in specific flow nedded for whatever application your running. Link to comment Share on other sites More sharing options...
