Dadinator Posted October 24, 2011 Share Posted October 24, 2011 I need the fender flare brackets for the rear flares. Particularly the passenger side. Mine are shot. Link to comment Share on other sites More sharing options...
Dadinator Posted November 7, 2011 Author Share Posted November 7, 2011 Still need them Rears! Link to comment Share on other sites More sharing options...
Dadinator Posted December 2, 2011 Author Share Posted December 2, 2011 Hello?????? Link to comment Share on other sites More sharing options...
flint54 Posted December 2, 2011 Share Posted December 2, 2011 How shot are they? Mine had the studs busted off and I was able to drill out those spots, insert bolts with the right thread and length, and spot weld the heads in place. They're very hard to salvage at the JY without busting off the studs, but it can be done if you're methodical and careful. Run a nut down on the exposed stud first to clear all the easy crud, then douse liberally with the penetrant of your choosing (I use PB Blaster), then heat with a torch (I know, most JY's forbid torches but I don't give a damn), which will ruin the plastic but that's not what you're after. Link to comment Share on other sites More sharing options...
Dadinator Posted December 3, 2011 Author Share Posted December 3, 2011 Wish it was that easy. The ones that I had were rusted to almost dust. The ones on the driver side were as you describe. I already fixed them and reinstalled. I need some passenger side ones. Link to comment Share on other sites More sharing options...
nitroxsteve Posted December 3, 2011 Share Posted December 3, 2011 I have a set in WV no rust but some of the studs are busted off or bent. If you interested in replacing the studs let me know and ill send you some picks later next week when I get back to WV to pick them up. Link to comment Share on other sites More sharing options...
Dadinator Posted December 5, 2011 Author Share Posted December 5, 2011 Yes, interested. How much you want for them? Link to comment Share on other sites More sharing options...
nitroxsteve Posted December 5, 2011 Share Posted December 5, 2011 Yes, interested.How much you want for them? Let me look at them to check the condition but I'm thinkin $10.00 for the set plus shiping if the are not rusty. Link to comment Share on other sites More sharing options...
