kyleag89 Posted September 26, 2011 Share Posted September 26, 2011 Ok the DW is back!! EVERYTHING in the front end is less than 1 1/2 years old, and YES it has been aligned. The only thing that is left is the control arms. The CAs are original 1989. Has anyone ever seen or used these LCAs before? http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_Lift-Lowering-Kit-Rancho_18580432-P_1351_R|GRPCHASAMS_1326856273____ I have 3" of lift in the front so I should be good for lengh. Link to comment Share on other sites More sharing options...
mvusse Posted September 26, 2011 Share Posted September 26, 2011 Stock replacement bushings for the control arms are only $8 or so. If you want to replace the control arms themselves, I like these, even though they are more expensive. RE also makes solid ones to for a bit less. Link to comment Share on other sites More sharing options...
kyleag89 Posted September 26, 2011 Author Share Posted September 26, 2011 This truck was my second vehicle and now its my DD to work. (All highway because its better on gas than my XJ) I need new arms because I am not fighting swapping bushings in 22yo arms. I added 3" spacers so longer arms is a good idea but not necessary. Also I have a very limited budget so the cheaper the better. Link to comment Share on other sites More sharing options...
bighause Posted September 26, 2011 Share Posted September 26, 2011 Have you checked to make sure it isn't the tires? My friends Rubicon had the wobble and threw parts/money at it for a while, it got better but it was never right. He and I swapped tires and it was like a new Jeep, consequently my MJ wobbled like crazy with his tires on it. He had balanced the tires at 2 seperate places before that and it never made a difference. If you know someone with similiar size tires, I'd swap them and see Link to comment Share on other sites More sharing options...
