86 comanche 2.5l
i put a rebuilt motor in my comanche 86 2.5l fuel inject. And on the back of the throttle bottle were the fuel lines go in. drivers and passenger side. of eachother. I took me a month or so to figure find a new fitting. Do you no which is the fuel in and fuel out. I havent mest with it for a month or so i forget.
Look at the two lines and you will see that one has a sharper bend than the other and is longer from the bend to the fitting. That is the fuel supply. It goes on the left hand side, The drivers side. The other line with the more gradual bend is the return line. It goes on the passenger side of the TBI.
