whitehorse Posted July 6, 2011 Share Posted July 6, 2011 My trusty (rusty) '86 2.8 trans lines are leaking right after they travel over the trans and start their journey forward. My question is for ease of replacement wouldn't it be simpler to run rubber hose from the fittings on the trans to the radiator than futz with the metal tubing? A does anyone know the size of the fittings on the trans? Where to get parts? Thanks Link to comment Share on other sites More sharing options...
banshee Posted July 7, 2011 Share Posted July 7, 2011 First question No don't use rubber, easy yes, able to operate/maintain the required pressure/temp No Second almost any parts store could get or most likely have the required fittingsā¦ B... Link to comment Share on other sites More sharing options...
whitehorse Posted July 7, 2011 Author Share Posted July 7, 2011 Thanks for your input. Do you know what trans is in my '86? It appears chrysler-ish. Link to comment Share on other sites More sharing options...
Garvin Posted July 7, 2011 Share Posted July 7, 2011 The trans you have is a Chrysler A904. From the looks of it, they used that from '84-'86 in both the I4 and V6 engines. Link to comment Share on other sites More sharing options...
whitehorse Posted July 7, 2011 Author Share Posted July 7, 2011 Thanks for the info. Link to comment Share on other sites More sharing options...
