89 Comanche in Oregon w/interesting dash, AC
http://portland.craigslist.org/wsc/cto/2452627788.html
Note: I suspect the dash and gages have been swapped. The seller doesn't mention A/C, but it is clearly there. Still, it shows potential.
Here is the ad copy verbatim:
4.0 I6 has 169,xxx that's only about 7,600 per year.
5Speed
Clean title- One owner, who ever buy's will be the Second owner
Whats good-
New Windshield as of 6/20
Strong Motor,
4x4 works great
Good Clutch
New Magnaflow Muffler, and Catalytic Converter
New High Volume Oil pump,
Has New Water pump, Thermostat, Thermostat Housing,
and Clutch Fan
Battery, and Alternator were replaced back in march by Les Schwab. Starter was replaced shortly after. Full tune up, Cap, rotor, Wire's, plugs
Tag's good till 12/12
New Brake Rotor's
New Steering stabilizer
A/C Works good
Heater blows good
has Kenwood Cd Player
Good tire's
Clutch Slave cylinder is about a year old
Bed has mat,
had a canopy on it since new i took it off cus its ugly to me.
One owner, been in family since new belonged to my Aunt, but she gave it to me and I just got laid off and could use the money I just put into it back.
The not so good,
Clear coat is peeling or peeled all over. very little rust which is rare for a older jeep
no head liner.
Carpet is dirty
seat has some stain's
Alignment is slightly off will start drifting to the right if you let go of the wheel,
I need to get the tires balanced and rotated still, has a slight shimmy around 50-55
You have to hold it in Reverse other wise it will tend to pop out of gear, only does it in reverse. Aunt said its done it since she can remember.
other than that nothing else is wrong. Comanche's are hard to find, and when you do they are in poor poor condition or are ever priced.
asking $1650
