Another Headliner Question
I am about to replace my headliner. I wondered if since the headliner was removed, the carpet panel underneath the rear window and the b-piller trim were both removed, should I add additional insulation behind those areas?
I know a lot of people have done that but I was curious if it really made a difference at deadening the sound?
I think it made a big difference, not just for sound but also for heat.
I have no data to back up my perception, but the use of reflective
layers has been well documented to reduce radiant heat gain. I put
the stuff in every place I could possibly reach, often cutting small
pieces to fit into crannies, like cab corners.
